Dashboard Pack - SQLFacts
This dashboard shows data from custom tables there were created using the SQLFacts utility. The SQLFacts utility must be configured and running before importing the SQLFacts dashboard for data to appear.
Within Dashboard Server create a new SQL provider called SQLFacts that points to the database where you installed SQLFacts.
How to add a SQL provider
Make sure you have access to the database you want to use.
Configuring access to a database for an SQL provider
To be able to query databases, such as the Operations Manager database, the Dashboard Server application pool identity needs to be given the db_datareader role in SQL Server Management Studio for the database you wish to query. See How to configure access to a database for use with the SQL tile.
Provider name:
Driver and Connection String:
Connection strings when you are using Microsoft SQL Server Driver
Connection string for any database:
With integrated security:
CopyServer=<SQLservername>;Database=<DatabaseName>;Integrated Security=True;
With username and password:
CopyServer=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
CopyServer=<SQLservername>\\<InstanceName>;Database=<DatabaseName>;Integrated Security=True;
Example:
CopyServer=SQLServer1\\Main;Database=CRMDB;Integrated Security=True;
If you want to specify a port
CopyServer=<SQLservername>,<PortNumber>;Database=<DatabaseName>;Integrated Security=True;
Example:
CopyServer=SQLServer1,51433;Database=CRMDB;Integrated Security=True;
Connection strings when you are using ODBC
Note: You need to use 64-bit ODBC drivers.
Example:
CopyDriver=<ODBCdriverName>;Server=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
If you are using a System DSN
CopyDSN=<DSNname>
Click save to save your new provider.
Publish the dashboard.
How to publish a dashboard
