Dashboard Pack - Salesforce
This is a really simple dashboard showing how to use the Salesforce API to query for data using SOQL (Salesforce Object Query Language). It displays summed up accounts, contacts and opportunities using the SOQL count function.
Get the latest version of DS for Azure
A Salesforce Admin needs to create a new Connected App in Salesforce with the following settings:
"Enable OAuth Settings" - activated
A callback URL in the format
https://your-squaredup-server-url/SquaredUpv5/ext-core-webapi/callback/Salesforce
Note: The last part of the URL has to be Salesforce, because it needs to be identical with the name of the provider you're going to create for the tiles in this dashboard.Granted OAuth scopes:
Manage user data via APIs (api)
Perform requests at any time (refresh_token, offline_access)
IP restrictions:
Change the
IP Relaxation
setting toRelax IP restrictions
in theEdit Policies
area.Alternatively, you can whitelist the IP address for your SquaredUp server in the
Profiles admin
area.
Create a Web API provider to connect to your Salesforce environment with the following settings:
Type OAuth Name Salesforce
Grant type Authorization code Base URL The base URL to your Salesforce environment in the format https://your-salesforce-org.my.salesforce.com/services/data/v52.0/
Ignore invalid SSL Off Send authorization with query Off Authorization URL https://login.salesforce.com/services/oauth2/authorize Token URL https://login.salesforce.com/services/oauth2/token Client ID and secret The
Consumer Key
of the Connected App you're using for SquaredUp DS. You can find it in Salesforce, in the App Manager area of the Connected App.Note: When creating a new Connected App in Salesforce, it can take 20-30 minutes before the Consumer Key becomes active for API usage. This may cause the provider to fail to authorize. If this happens, wait 10 minutes and then click Perform Authorization again.
Client secret The
Consumer Secret
of your Connected App you're using for SquaredUp DS. You can find it in Salesforce, in the App Manager area of the Connected App.Authorization scope api offline_access How to create a Web API provider
In SquaredUp DS navigate to the right-hand menu ☰ > system > Integrations
Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.
In DS for Azure go to the top right hand menu ☰ > Import Dashboard Packs and drag the zip file into the Manual Import box.
Each tile has a Salesforce SOQL query in the Headers & Data panel. Change the query to a query that works for your Salesforce environment:
Publish the dashboard.
How to publish a dashboard
