How to use the Resources tile
The Resources tile contains two different kinds of tiles:
The Matrix tile shows health state, performance metrics and other information for a list of monitored resources.
The Resources Summary tile allows you to show a summary of resources, resource groups and subscriptions.
How to configure a Resource tile
Create a new tile on a dashboard or perspective and select the Resource tile.
Choose the type of Resource tile you want to configure:
Matrix
See How to use the Matrix tile
Summary
Summary Scalar
The Summary Scalar visualization allows you to show the total number of all resources in a scope. For example you might set the scope to a particular subscription, then filter by type to show virtual machines and change the unit to 'VMs'.
Summary Grid
The Summary Grid visualization allows you to show a table representation of the total number of resources for the scope and grouping you have specified. You can also group and sort the table.
Summary Bar
The Summary Bar visualization shows you a graph representation of the total number of resources for the scope and grouping you specify.
Scope:
Select the scope for your tile.
Scope options on dashboards
Filter by tenant By default results are shown across all tenants. In SquaredUp DS 4.7 and above a user who has access to multiple tenants will see a filter by tenant option.
If you see the message "You do not have access to all of the tenants currently selected" or "Tenant ID could not be resolved"
In a multi-tenant environment a user who does not have access to all tenants will see this message if they attempt to edit a scope containing tenants that they do not have access to. This may be because:
- One SquaredUp DS admin has added a tile scoped to tenants that other SquaredUp DS admins do not have permissions to.
- The customer/tenant is no longer serviced by this Customer Service Provider (CSP), so the tenant has been permanently removed for all SquaredUp DS admins.
Symptoms
A tile scope shows:
Procedure
You can add multiple items. To remove an item click the x to the right of its name.
Tip: Start typing and after two characters you'll see suggestions that match the name appear.
Filter by type:
Filter by type:
Filter by type:
databases
and selectingSQL databases
.Show hidden types This works in the same way as the Show hidden types option in the Azure portal.
Scope options on perspectives
The power of perspectives is that tiles on a perspective can use a dynamic scope. A dynamic scope considers the currently viewed resource. A dynamic scope consists of two different states:
the actual resolved scope that depends on which resource you are currently viewing ("this object has 5 child objects of type logical disk")
After configuring the dynamic scope once in the tile, you'll get different results depending how the scope is resolved on the different resources you are viewing.
On perspectives, you can scope tiles to:
this resource
other resources Gives you the normal, non-dynamic scope options you are used to when scoping tiles on dashboards. This means the tile will not dynamically adapt it's content to the currently viewed resource, it will always show data for the static resource picked here.
Since the power of perspectives is that their tiles can show data for different resources depending on what resource is currently being viewed, you should only select this option when you are sure that there is no relationship between the desired scope and the currently viewed resource.
Configure the settings for your visualization:
Settings for Scalars
Scalar
Color
Conditional formatting:
You can display the data in different colors based on values you define here. For example, you can display the data in green when the value is below 100 and in red when it is above 100.
value
property and manipulate it with JavaScript String and Regex APIs. When you click on the mustache picker, you'll get some examples:Value is greater than something, less than something, etc.
For example:
{{value < 10}}
(The color you pick will be used if the value is less than 10)Value is present in the result (scalar tiles only)
For example:
value.IndexOf('error') != -1
(The color you pick will be used if the string value "error" is present in the results)Value matches one of the regular expressions you defined (scalar tiles only)
For example:
value.match(/healthy|good|up/)
(The color you picked will be used if the string values arehealthy
,good
, orup
Display:
, where123
.For scalars, you can only use the dynamic property
value
in dynamic links, which means the link changes when the value of the scalar changes. Since a scalar is just one item, it would also make sense to use a fixed link, for example the link to the website of which you are displaying the response time.For status icon or bars and the rows of a grid, you usually want to use a dynamic link since you get multiple items or rows that represent different things. You can use any of the dynamic properties the mustache picker offers you.
Examples for URLs with dynamic properties for popular APIs
Dynamic mustache properties and values you need to change according to your instance are highlighted in bold.
ServiceNow incidents:
PagerDuty incidents:
{{incident.html_url}}
Azure DevOps projects:
Azure DevOps builds:
Zendesk tickets:
Azure Application Insights
Settings for Grids
Grouping
Grouping
Allows you to control how the information is counted and displayed.
Note: If you've scoped to a resource type, such as Virtual Machines, then you should use another grouping method, such as resource group, tag, or custom.
Custom grouping:
Custom grouping allows you to group the resources being shown by any property or combination of properties, for example
{{location}}
. You need to specify the properties just like you would do when you're creating a custom label, see How to use Custom Labels.Note: When the tile is scoped to a resource type or the resource type filter is set, additional properties become available for custom grouping. For example, you can define a label that includes the location property (always available) and the VM size property (only available when the scope is filtered to Virtual Machines) to group VMs by their location and size.
The Summary Grid below is grouped by type:
Sort
If you activate the checkbox limit number of results displayed you can limit the results to a number of results (from the top).
Settings for Bar Graphs
Grouping
Custom grouping:
{{location}}
The Summary Bar visualization below is scoped to a subscription which is filtered by type to virtual machines. It is then grouped by custom > {{location}}:
Sort
Data Range
Click done to save the tile.
Walkthrough: Using the Summary Grid tile to show a count of all virtual machines by VM size
This walkthrough shows you how to add a Summary Grid visualization to a dashboard.
Create a new tile and click Resources.
Click on the Summary Grid button.
In the scope panel add a resource group or subscription. Tick filter by type and in the box type
Virtual machines
.In the grouping section click custom. In the label box type
location / VM size
. We're going to create a custom label.In the value box copy and paste the following:
Copy{{location}} / {{properties.hardwareProfile.vmSize}}
The mustache helper button to the right of the value box shows all the options available along with an example value. Instead of coping the mustache syntax above, you could select
{{location}}
from the dropdown list. Then type/
and then click the mustache button again and select from the dropdown:{{properties.hardwareProfile.vmSize}}
In sort check that value and descending are selected.
Click done.
