Kubernetes Monitoring dashboard (with Prometheus)
This dashboard visualizes the performance of a Kubernetes cluster by getting metrics from Prometheus using PromQL in the Web API and PowerShell tiles.
  • Basic cluster information displayed in a grid
  • Network traffic sent and received for the cluster
  • CPU, memory and disk utilization for the cluster
  • CPU, memory and disk used by each node in the cluster
The tiles on this dashboard automatically adjust the queries to Prometheus based of the page time frame being selected. The Rate and Step variables are handled in the PowerShell profile and can be amended as required.
    Get the latest version of SquaredUp DS for Azure
    Try it for free
  2. Create a Web API provider to connect with Prometheus.
    Use the following settings:
    Type
    Basic Auth
    Name
    Prometheus
    URL
    URL of your Prometheus instance API endpoint, for example https://<your-prometheus-url/api/v1/
    Username and password
    Enter the credentials for your Prometheus environment
  3. Create a PowerShell profile in SquaredUp DS with the following settings:
    Name
    Prometheus
    Sets the Prometheus API endpoint, changes step and rate values based on the timeframe of the page, and gets the page timeframe start and end.
    Script
    Copy and paste the script below, replacing <your-prometheus-url> with your Prometheus instance API endpoint. Modify the PowerShell profile to handle the authentication method required by your deployment of Prometheus.
  4. Download and import this dashboard pack.
