VM Insights Metrics
This dashboard uses Log Analytics tiles to display key metric data for Virtual Machines, regardless of where the servers are hosted. This dashboard focuses on insights about virtual machines, such as free disk space, CPU performance and security issues.
Get the latest version of SquaredUp DS for Azure
- In DS for Azure go to the top right hand menu ☰ > Import Dashboard Packs and drag the zip file into the Manual Import box.
Enter your Azure workspace in each tile.
- Open the workspace panel.
- Select your Azure workspace.
Publish the dashboard.
