Au2mator
This dashboard uses SQL and PowerShell tiles to present performance and health counters for the au2mator- Self Service Portal and a Web API tile to directly open the Self Service Portal in a new tab.
It also contains a quick overview of automation engines, System Center Orchestrator and Azure Automation Runbook Health.
Total Requests (SQL tile - Donut) | Displays the actual state of all requests and their state. Note: This tile uses the page timeframe in its SQL query. |
Heavy Users (PowerShell tile - Donut) | Shows heavy users. Since the au2mator DB only contains the SamAccountName, PowerShell is used to provide the DisplayName from ActiveDirectory. |
Total Services (Scalar) | The number of au2mator Services. |
Top 8 Service Usage (SQL tile - Donut) | The top 8 services by usage. |
Start au2mator (Web API tile) | To start the au2mator – Self Service Portal in a new tab. |
Runbooks Job Status (SQL tile - Donut) | Displays all Runbook Jobs which have the state of failed, warning, or success. Note: This tile doesn't use the page timeframe in its SQL query. |
Running Runbooks (SQL tile - Grid) | A list of all Running and Queued Runbook jobs. Note: This tile doesn't use the page timeframe in its SQL query. |
Azure Automation (Azure Log Analytics tile - Donut) | Displays the Azure Automation Runbook Jobs state. Note: This tile doesn't use the page timeframe in its SQL query. |
Get the latest version of SquaredUp DS for Azure
- In DS for Azure go to the top right hand menu ☰ > Import Dashboard Packs and drag the zip file into the Manual Import box.
- Replace the connection string in the SQL tiles (Total Requests, Total Services, Top 8 Service Usage, Runbook Job Status, Running Runbooks) with the connection string to your own au2mator database.
- Open the connection panel.
- Enter the connection string to your own au2mator database.
- Edit the script in the Heavy Users PowerShell tile to query data from your au2mator database.
- Edit the tile by clicking the Edit button.
- Open the script panel.
- Insert your au2mator database.
- Edit the Start au2mator Web API tile to connect to your au2mator Self Service Portal.
- Open the content panel.
- Insert the URL to your au2mator Self Service Portal.
- Enter your Azure workspace in the Azure Automation tile.
- Open the workspace panel.
- Select your Azure workspace.
Publish the dashboard.
