How to add a Pingdom provider
Before you configure the Web API tile for use with Pingdom you need to create a Pingdom provider in Dashboard Server. For more information on how to use the tile see How to use the Web API tile with Pingdom
You may like to refer to the Pingdom API documentation or speak to your Pingdom expert.
For Pingdom the provider must be created as a simple provider:
Add the following:
value:Bearer
<API token from Pingdom>
Bearer
and a spaceClick Save.
