SQL provider
What are Integrations?
What is a provider?
- dedicated providers that connect to a specific external platform or database (SQL, ServiceNow, Azure Active App Insights, Elasticsearch, etc.)
About SQL providers
Since SquaredUp DS version 5.4 you need an SQL provider to use the SQL tile. . If you haven't created an SQL provider yet, you need to create a provider first.
If you created SQL tiles before SquaredUp DS version 5.4, they were created with a connection string in the tile instead of a provider.
Adding an SQL provider
- Make sure you have access to the database you want to use.
To be able to query databases, such as the Operations Manager database, the SquaredUp DS application pool identity needs to be given the db_datareader role in SQL Server Management Studio for the database you wish to query. See How to configure access to a database for use with the SQL tile.
- Provider name:
Enter a name for your provider that makes it easy for you to identify. You can't change the name after you created the provider. - Driver and Connection String:
The connection string depends on your database and the driver you've chosen:Connection string for any database:
With integrated security:
Server=<SQLservername>;Database=<DatabaseName>;Integrated Security=True;With username and password:
Server=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;If the SquaredUp server and SQL server are in the same domain you can just use the SQL server name, if they are not in the same domain you should use the fully qualified domain name.
Server=<SQLservername>\\<InstanceName>;Database=<DatabaseName>;Integrated Security=True;Example:
Server=SQLServer1\\Main;Database=CRMDB;Integrated Security=True;If you want to specify a port
Server=<SQLservername>,<PortNumber>;Database=<DatabaseName>;Integrated Security=True;Example:
Server=SQLServer1,51433;Database=CRMDB;Integrated Security=True;Note: You need to use 64-bit ODBC drivers.
Example:
Driver=<ODBCdriverName>;Server=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;If you are using a System DSN
DSN=<DSNname> - Click save to save your new provider.
To use the SQL provider in a tile see How to use the SQL tile
