Octopus Deploy
This dashboard gives an overview of deployments and tasks from Octopus Deploy
| Deployments (Donut) | High level view of all deployments |
| Tasks (Grid) | High level view of all tasks |
- Ensure you're using SquaredUp DS v5.4 or above. - Already a SquaredUp customer? - Get the latest version of SquaredUp DS for Azure - New to SquaredUp?
- Create a Web API provider to connect with your Octopus Deploy environment.
 Use the following settings:TypeSimple authNameOctopusDeployNote: The name is case-sensitive and must be entered exactly like given here for the tiles to recognize the provider automatically. If you name it differently, you will need to select the provider manually for each tile on the dashboard. URLEnter the base url for the Octopus API, i.e. https://octopus.company.com/apidefault headersEnter your Octopus Deploy API key in the following format:First box (name):x-Octopus-ApiKeySecond box (value):Token( i.e. API-LKASJDLKAJDLKASLDKJ)- In SquaredUp DS navigate to the right-hand menu ☰ > system > Integrations
- Under Integrations click on Web API and choose either Simple, Basic Auth or OAuth depending on the API you are using.  Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.Simple Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.SimpleNo authentication, basic authentication (username and password in a header) or Windows authentication (configured automatically to use the application pool identity account). Basic authBasic authentication. Your specified username and password will be Base64 encoded automatically. OAuthToken-based authentication according to the OAuth 2.0 standard. Many APIs use OAuth 2.0 for authorization, and will require an OAuth provider to include the additional information about how to authorize against the service.
- Complete the provider fields, using your API provider's online documentation as a guide. ignore invalid ssl: Turn the on/off switch to on if you are using a self-signed certificate. default headers headers sent with all requests using this provider, for example the API token in the format the API requires. url parameters url parameters sent with all requests using this provider. For example, a query parameter that is always used can be added here in the provider to save adding it to every dashboard configuration.
- You are now ready to use this provider in a Web API tile (see How to use the Web API tile).
- Download and import this dashboard pack. - Download the dashboard pack zip file for the dashboard pack you wish to import. There may be additional steps before or after the import to get the dashboard working in your environment.
- In DS for Azure go to the top right hand menu ☰ > Import Dashboard Packs and drag the zip file into the Manual Import box.
