How to add an SQL provider
What are Integrations?
Dashboard Server Integrations allow you to create your own providers. Each Integration has its own form to help you input the information required for different providers.
What is a provider?
About SQL providers
Since Dashboard Server version 5.4 you need an SQL provider to use the SQL tile. . If you haven't created an SQL provider yet, you need to create a provider first.
Adding an SQL provider
Make sure you have access to the database you want to use.
Configuring access to a database for an SQL provider
To be able to query databases, such as the Operations Manager database, the Dashboard Server application pool identity needs to be given the db_datareader role in SQL Server Management Studio for the database you wish to query. See How to configure access to a database for use with the SQL tile.
Provider name:
Driver and Connection String:
Connection strings when you are using Microsoft SQL Server Driver
Connection string for any database:
With integrated security:
CopyServer=<SQLservername>;Database=<DatabaseName>;Integrated Security=True;
With username and password:
CopyServer=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
CopyServer=<SQLservername>\\<InstanceName>;Database=<DatabaseName>;Integrated Security=True;
Example:
CopyServer=SQLServer1\\Main;Database=CRMDB;Integrated Security=True;
If you want to specify a port
CopyServer=<SQLservername>,<PortNumber>;Database=<DatabaseName>;Integrated Security=True;
Example:
CopyServer=SQLServer1,51433;Database=CRMDB;Integrated Security=True;
Connection strings when you are using ODBC
Note: You need to use 64-bit ODBC drivers.
Example:
CopyDriver=<ODBCdriverName>;Server=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
If you are using a System DSN
CopyDSN=<DSNname>
Click save to save your new provider.
