Symptoms
When activating SquaredUp DS you see:
or
Procedure
Your Primary Production license key can only be activated once.
If you uninstall and reinstall on the same server and you originally carried out an offline activation (as described in How to activate your license offline (manual activation))then you can reuse the same .bin file by browsing to <SquaredUpURL>/InstallLicense. The .bin file cannot be used on a different server.
