After installing SquaredUp DS you will be prompted to login and enter a license activation key. You will have been emailed an activation key (often called a license key), which is then activated against a SquaredUp DS installation.
When you apply for a free trial you receive an unrestricted 30 day evaluation to try out all features in your own SCOM environment: Request a free trial activation key. If you've previously had a trial, or your trial has expired please contact SquaredUp Support
Drag the .bin file into the box that says Drop license file or click to install. To return to the screen above browse to <SquaredUpURL>/InstallLicense and log in as an administrator.
If you deployed SquaredUp DS from the Azure Marketplace:
The URL is https://DNSName of the virtual machine (VM) deployed.
Once the file has uploaded click Next and then complete the setup wizard.
If you uninstall and reinstall on the same server you can reuse the same .bin file by browsing to /InstallLicense. The .bin file cannot be used on a different server.
