Welcome to SquaredUp DS for Azure
DS for Azure gives you and your team live, interactive and shareable dashboards for your Azure applications, resources and services.
Two ways to install DS for Azure
Deploy via the Azure Marketplace
The easiest way to start is to deploy DS for Azure from the Azure Marketplace. We create a virtual machine in your Azure tenant, running our web application and IIS, and a read-only Azure application in your Azure AD that will populate your dashboards by querying Azure APIs in real-time. If you don't already have a license for DS for Azure, we will email you a free 30 day trial license to get you started when you create your first deployment from the Marketplace.
For more information see How to deploy SquaredUp DS for Azure from the Azure Marketplace
Use the downloadable installer
You may prefer to use the DS for Azure downloadable installer rather than deploy via the Marketplace. For example, if you wish to deploy on an existing Azure virtual machine, a non-Azure machine, or due to security factors.
For a step-by-step guide to installing DS for Azure using the downloadable installer please see How to install SquaredUp DS for Azure using the installer
More information
Take a look at the What's New in SquaredUp DS for Azure article and the Release Notes for SquaredUp DS for Azure for more information on the updates and new features.
If you need assistance, or have any feedback, please just open a ticket using the form at the top right of this Knowledge Base.
Dashboard Gallery
GitHub repository
In our GitHub Samples repository you will find useful samples from SquaredUp DS and the Community to enhance your experience of using SquaredUp.
SquaredUp Blog
To keep up to date with what's happening at SquaredUp don't forget to check out our blog!
SquaredUp Support
The documents on this support site cover everything you should need to know. If you have questions please contact SquaredUp Support.
