After installing SquaredUp DS you will be prompted to login and enter a license activation key. You will have been emailed an activation key (often called a license key), which is then activated against a SquaredUp DS installation.
Free trial
Purchased SquaredUp DS
When you buy SquaredUp DS you will be emailed your license keys. If you do not have a license activation key please contact SquaredUp Support.
Types of license keys
Trial license | This license allows for unlimited users and all features for a 30 day evaluation in your own environment and is available from here |
Primary Production license | This license should be used on your SquaredUp Production server. |
Test & Development license | This license is for your test environment so that you can experiment with configuration changes and new versions without affecting production. It is included free of charge with a purchase. |
Activating SquaredUp DS when the server does not have internet access
Browse to
<SquaredUpURL>/activation
to get to your server's activation screen.Log in as an administrator. See How to make a user a SquaredUp DS administrator
Click on offline activation. If SquaredUp DS is already activated the link will show as offline reactivation.
If you see a message that the maximum number of activations has been exceeded see "License already activated" or "Maximum activations reached" or contact SquaredUp Support.
<SquaredUpURL>/InstallLicense
, and log in as an administrator.Once the file has uploaded click Next and then complete the setup wizard.
If you uninstall and reinstall on the same server you can reuse the same .bin file by browsing to <SquaredUpURL>/InstallLicense
. The .bin file cannot be used on a different server.
