In-product Notifications
Notifications are only visible to SquaredUp DS administrators (see How to make a user a SquaredUp DS administrator).
SquaredUp DS will periodically check for new notifications, which are visible from the top right-hand menu ☰ either via notifications or under system -> notifications. Notifications have different severity levels from informational (such as a new product release) to critical (e.g. license expiry).
Dismissing Notifications
