Pinned Perspectives
What is a pinned perspective?
Pinning a perspective to the navigation bar creates a handy shortcut to a perspective for a specific resource. Usually, you first need to navigate to the specific resource to be able to choose what perspective you want to see. By pinning the perspective to the navigation bar, you can go to one specific perspective directly.
Note: A pinned perspective is one perspective for one specific resource. Even though a perspective can be available for different resources of the same type, pinning a perspective does not mean you pin the perspective to the navigation bar and then choose the resource you want to see. The pinned perspective will be about the one resource you were viewing when you pinned the perspective.
Use cases for pinned perspectives
In addition to creating a shortcut on the navigation bar, pinned perspectives offer you two further options:
You can add the pinned perspective to a Team Folder to control who can view the pinned perspective.
Note: Only Dashboard Server Admins can create and edit perspectives. This applies also to pinned perspectives in Team Folders. While a normal dashboard in a Team Folder can be edited by users when they have the author or owner role for the Team Folder, a pinned perspective in a Team Folder can't be edited by users, even if they have the author or owner role, since editing a perspective affects all resources of the same type.
For more information about Team Folders and roles see Team Folders.
How to create a pinned perspective and directly move it into a Team Folder
Note: Only Dashboard Server Admins can create pinned perspectives.
Go to the resource you want to pin a perspective for.
Choose the perspective you want to pin for this resource from the perspective ribbon.
Click on the Share this dashboard button at the top right of the page. This button is only visible when you are not in edit mode.
Under Pin this perspective as a dashboard, click on the select location button.
You'll see your navigation bar displayed as a tree structure. At the bottom of the tree you'll see the perspective as a new item highlighted in red. Drag the perspective into the navigation bar structure as you require.
Note for Team Folders: If you want to add the perspective to a Team Folder you need to select the Team Folder from the drop down list at the top of the tree structure first.
Name of the pinned perspective: By default, the name of the pinned perspective is the name of the resource (and resource group if applicable) followed by the name of the perspective. You can edit the name by clicking on it.
Click the pin perspective button at the bottom of the navigation structure.
How to move an existing pinned perspective into a Team Folder
Who can move dashboards and pinned perspectives?
From the navigation bar into a Team Folder: Only Dashboard Server Admins, as only Admins have permissions to edit a globally viewable dashboard.
From a Team Folder to the navigation bar: Only Dashboard Server Admins, as only Admins have permissions to add a globally viewable dashboard.
From one Team Folder into another Team Folder: You need to have an owner or author role for both Team Folders (Dashboard Server Admins automatically have the owner role for both).
How to move a dashboard or pinned perspective
Go to the dashboard or pinned perspective you want to move.
Note: You need to go to the individual dashboard or pinned perspective because they can only be moved from there. You can't move dashboards in and out of Team Folders via the Team Folder settings or the edit navigation settings, but you can go to the dashboard or pinned perspective you want to move from there by clicking on the view dashboard button.
Click the edit this dashboard button:
Click the move button:
You'll see the navigation bar as a tree structure. The team folder dropdown list at the top shows all the Team Folders you have the author or owner role for. Dashboard Server Administrators will see the everyone option in addition to all Team Folders in this dropdown list as only they can add or remove dashboards to or from the navigation bar.
Select the Team Folder you want to move the dashboard in to.
If there are other dashboards in the Team Folder, drag your dashboard into position in the navigation structure.
Click the move button to complete the move.
You can publish the pinned perspective via Open Access to make it visible for others who can't login to Dashboard Server (for more information about publishing with Open Access see Sharing Dashboards with anyone - Open Access)
How to publish a pinned perspective via Open Access
Go to the dashboard or pinned perspective you want to create an Open Access URL for.
Make sure the dashboard or pinned perspective is already published. If it is still a draft, publish it first.
Click on the share this dashboard button. If you can't see the button, check if you are still in edit mode since this button is only visible when you are not in edit mode.
You'll see the following sharing options:
In the Open Access section toggle the enable open access button to on.
You will see the message 'Preparing your Open Access dashboard, please wait' and a thumbnail of the dashboard itself:
Click preview to view the dashboard in Open Access mode.
Sharing options
Normal The sharing option Normal creates a link to the normal dashboard or perspective, meaning as a fully interactive version. Accessing the dashboard or perspective requires authentication with a Dashboard Server user license. The link is based on the dashboard's or perspective's ID and does not change when the dashboard or perspective is renamed.
Full-screen:The URL based on the ID, but with
?display=fullscreen
appended. This will hide the navigation bar.Embed: The URL based on the ID, but with
?display=embed
appended which will hide the navigation bar and page title.If the URL already uses a
then you will need to append&
first, for example,&?display=embed
Open Access The Open Access feature allows you to share your dashboards with anyone, even if they are not a licensed Dashboard Server user. It creates an Open Access version of the original dashboard that can be accessed via its own URL without the need to login. Open Access dashboards are perfect for embedding them in user portals like Sharepoint, pushing them to wall monitors or using them as high-level reports for managers.
For Dashboard Server v4: Less interactive means viewers of the dashboard can't hover to see graph figures and labels or click to drill down. The Open Access dashboard is server-rendered bitmap version of the original dashboard, that refreshes every time the original dashboard refreshes.
For Dashboard Server v5: Less interactive means viewers of the dashboard can hover to see graph figures and labels. If your dashboard contains links to external tools, for example linked rows in a grid, vierwers can click those links. If viewers click on Azure data to drill down to further data they will have to log in.
After a dashboard is updated the changes are shown on the Open Access dashboard when it next refreshes, usually in 60 seconds. On Dashboard Server v4 this may take up to 20 minutes.
Navigating from a pinned perspective to the resource
A pinned perspective shows a go to drilldown button which takes you to the resource. From there, you can see the perspective ribbon again and choose between all available perspectives for that resource.
Editing a pinned perspective
When you are viewing a pinned perspective and click on the edit this dashboard button you'll get a message that this dashboard is a pinned perspective and can't be edited here.
When you click on edit perspective you'll get to the resource that contains the perspective. Here you can navigate to the perspective and edit it like a normal perspective.
Note: The changes you make to the perspective will apply to all resources for which the perspective is available, not just for the one resource that is shown in the pinned perspective.
How to delete a pinned perspective
The easiest way to delete a dashboard, perspective, or pinned perspective is to navigate to it, click the edit button and then click the delete button.
If a dashboard or perspective is not published yet (draft), the discard and discard changes buttons will delete it.
If the dashboard or perspective has been published, and then you make changes, discard will discard the changes and leave the previously published dashboard or perspective live.
If you unpublish a dashboard or perspective and then discard changes then the dashboard or perspective will be deleted.
More options to delete a dashboard or pinned perspective
Other options to delete a dashboard or pinned perspective are:
You can delete the dashboard or pinned perspective from the navigation bar. Deleting it from the navigation bar will delete it completely, not just from the navigation bar.
Information about editing the navigation bar
The global navigation editor is accessible only by Dashboard Server administrators (How to make a user a Dashboard Server administrator) from the right-hand menu ☰ > edit navigation or system > dashboards.
This allows Dashboard Server administrators to reposition globally viewable folders and Team Folders on the navigation bar, as well as the ability to move any globally viewable dashboards.
The edit team folder icon is shown next to Team Folders and clicking it will take you to the Team Folder settings page where you can view and sort the dashboards within the Team Folder. The view folder button takes you to the folder itself to view or edit that folder. The delete button will delete items. This deletes the dashboard or folder and sub-contents completely, not just from the navigation bar. If the dashboard or pinned perspective is in a folder, you can go to the folder settings
, click the edit
