How to configure TLS/SSL (HTTPS) during a new installation - this option can be used when using the downloadable installer.
How to manually configure TLS/SSL (HTTPS) - this option can be used to configure TLS/SSL (HTTPS) at any time after installation.
HTTPS is required to login to Azure Edition.
When deployed by the Marketplace Dashboard Server can either be configured with a self-signed certificate with 12 months expiry, or a What is a Let's Encrypt certificate?. It is best practice to replace a self-signed certificate with a trusted certificate prior to moving into production.
When deployed by the Marketplace Dashboard Server will have configured a self-signed certification with 12 months expiry. It is best practice to replace this with a trusted certificate prior to moving into production.
When using the downloadable installer to install Azure Edition you will need to choose how you want to configure the SSL certificate.Azure Edition will only work using HTTPS.
You have three options:
If you are trialing Dashboard Server, and are unsure which option to choose, you may choose to use a self-signed certificate for the duration of the trial.
If you are accessing Dashboard Server via a public IP address it is best practice to purchase a trusted SSL certificate.
If you are accessing Dashboard Server internally you can use an AD domain issued certificate.
Existing certificate
What this does:
When to use this:
Only choose this option if port 443 is not already being used for another app. If port 443 is already in use, or you wish to specify an IP address or different port number, then you should chooseConfigure later.
You should choose this option if you have already acquired and imported a trusted certificate. For example, if you are deploying Dashboard Server on a web server that has already previously had a trusted certificate configured. This could be for a different application or for a previous Dashboard Server installation.
What this does:
When to use this:
If you choose this option to use a self-signed SSL certificate then Dashboard Server users will see a browser warning and will need to explicitly agree to proceed. In Chrome this is done by clicking Advanced.
If you are trialing Dashboard Server, or unsure which option to choose, you may choose to use a self-signed certificate.
If you are accessing Dashboard Server across the public internet it is best practice to use a trusted SSL certificate and not a self-signed certificate.
Configure later
What this does:
This will not configure any SSL bindings, you will need to configure an appropriate binding manually within IIS.
While you can choose to configure the SSL certificate later, please note that Dashboard Server will not work until https has been configured with a SSL certificate.
When to use this:
You already have websites using port 443, or wish to use a different port number or IP address combination.
How to configure your own certificate
See below: How to manually configure TLS/SSL (HTTPS)
If you are trialing Dashboard Server, and unsure which option to choose, you may choose to use a self-signed certificate for the duration of the trial see How to generate a self-signed certificate.
- If you use a load balancer the Subject Alternative Name of the TLS/SSL certificate you install will need to contain your load balancer's name.
- If the SquaredUp server is not behind a load balancer then the Subject Alternative Name should contain the name of the SquaredUp server name.
Subject Alternative Name entries can be wildcard names, such as *.squaredup.com or specific names such as monitoring.squaredup.com, however the entry should match what users will type in their browser to access Dashboard Server, otherwise the browser will display a message indicating that the certificate is not trusted.
You will need to connect to your SquaredUp server. See How to connect to your SquaredUp server.
Open IIS Manager on your SquaredUp server.
Under Connections click on your SquaredUp server.
Double-click Server Certificates in the central panel:
Double-click on a certificate in the central panel.
Click the Details tab in the certificate properties and then find Subject Alternative Names in the list:
The entries for this property will be displayed in the lower pane.
Under Connections click on the SquaredUp server.
From the right-hand menu click Import and follow the steps to import your certificate:
Under Connections expand Sites and click on the website that hosts the Dashboard Server instance (on Azure this is usually SquaredUpv4 or SquaredUpv5).
From the right-hand side menu click on Bindings.
Click Add:
Change the Type to https.
Under SSL certificate select the TLS/SSL certificate you added:
Click OK and then Close:
From the right-hand menu click Restart:
If there is an existing HTTPS binding configured on the web site (for example, because it hosts other applications in addition to Dashboard Server) and the certificate being used for the existing binding does not have a Subject Alternative Name entry that is appropriate for users to use to access SquaredUp, then a new binding may need to be created for a new certificate. Either a different port number or host name will then need to be set in each HTTPS binding entry if they are bound to the same IP address.
Open IIS Manager and click on the website that hosts the Dashboard Server instance (on Azure this is usually SquaredUpv4 or SquaredUpv5).
Copy(.*)
Copy{HTTPS}
Copy the following and paste into the the Pattern box:
Copy^OFF$
Click OK.
Copyhttps://{HTTP_HOST}/{R:1}
Change the Redirect type from Permanent (301) to See Other (303).
Click Back to Rules.
FAQs
If you choose the option to use a self-signed SSL certificate then Dashboard Server users will typically see a browser security warning and will need to explicitly agree to proceed. For example, in Chrome this is done by clicking Advanced, in Edge by clicking Details.
