How to use Custom Labels
Custom labeling allows you to specify exactly how you want resources to be displayed, using both static text and dynamic properties.
Supported tiles
Tiles that support custom labels come preconfigured with some useful labels and, in the case of Performance tiles, will even attempt to automatically select the most useful label based on the selected resource and metric. You can however choose the custom option which will allow you to precisely control the label.
The following tiles support custom labels:
- Status
- Performance (Bar, Line graph, Sparklines)
- Matrix
- Image
- SQL (Grid)
- Web API (Grid)
- Azure Log Analytics(Grid)
- App Insights (Grid)
You can configure a custom label by configuring the label panel when creating or editing a supported tile.
Mustache Parameters
Custom labels can use Mustache parameters (mustache syntax) to insert properties. If you're familiar with mustache, you can specify advanced labels that can transform properties prior to displaying them (such as showing only a portion of text, converting a number or reformatting a date).
A mustache parameter is a dynamic value, the actual value will be inserted from the properties of the object(s) in scope.
This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this plugin will send the query multiple times, once for each object. The results are then displayed together, for example in a single table.
You can use properties of objects and write them in between curly braces e.g {{name}}
to use them as mustache parameters. Whenever you use mustache parameters, you need to use a scope of objects that contain the property you're referencing.
For example, if objects of type "host" have a property called name
, you can use {{name}}
. This will resolve {{name}}
to the value of the name property of the different "host" objects used in the scope.
For example you can use the javascript split method to separate properties into substrings to make the result more readable.
The mustache helper
When specifying a mustache for a custom label, clicking the {{}} button or typing {{
brings up a helpful picker which shows all the properties of your selected resources, along with sample values.
Once the mustache helper is displayed, the list of properties will automatically filter based on what you type, allowing you to quickly find a property using a partial name or likely term. Clicking an item in the list will automatically insert that property into your label and complete the mustache.
Property names are case-sensitive and should be written as they appear in the mustache helper (e.g. availabilityStatus.location
not AvailabilityStatus.location
Note about using properties with hyphens from external APIs (for Web API, Elasticsearch, and Splunk tile)
Property names that contain hyphens (for example properties.name-with-hyphens
) can't be processed due to a JavaScript limitation. If you want to use a property that contains a hyphen, you have two options:
Original property name:
New format:
Display virtual machines with a custom sub-label
You may wish to specify your own sublabel rather an use the default resource summary sublabel.
Create a Status resources (icons) tile.
On the scope panel select type and enter
Virtual Machines
.Click on the sublabel panel.
Click on custom.
In the sublabel template paste in
Copy{{location}} {{properties.storageProfile.imageReference.offer}} {{properties.storageProfile.imageReference.sku}}
Click on done.
You can use timeago
to convert Unix timestamps from milliseconds to show a readable date and time. You can either display an absolute time (for example, August 20th 2021) or a relative time (for example, 20 hours ago).
The parameters for the value you want to convert can either be true
or false
Show Absolute |
Show Time |
Without Suffix |
With Prefix |
Tip: The default setting for all parameters is false
. If you only want to change the first parameters, you can just use timeago(value, true, true)
and it will be interpreted as timeago(value, true, true, false, false)
Examples:
{{timeago(value)}}
To display the absolute time as the date without the time:
{{timeago(value, true)}}
To display the absolute time as the date with the time:
To display the time with the prefix "for" for relative time and "since" for absolute time (for example, "the status has been unhealthy for 10 hours")
Option A) Use the fourth parameter and set it to true
. This will insert the appropriate prefix for the absolute or relative time:
timeago(value, false, false, true, true)
Option B) You can leave out the fourth parameter that controls if the prefix "for" or "since" is inserted automatically. Since you left it out, it defaults to false, causing no prefix to be shown. Instead you insert the word "for" or "since" manually before the timeago function.
for timeago(value, false, false, true)
To convert a time value from seconds to milliseconds:
{{timeago(value*1000)}}
Example with a Pingdom property:
