Action buttons for dashboards and perspectives
About action buttons
Action buttons are customized buttons that you can add at the top of a dashboard or perspective.
Open an internal link
An internal link within your SquaredUp DS instance. For example, when you want to link from an object's perspective to a dashboard that is relevant for that object.Internal links use only the part of the URL that comes after .../SquaredUpv[version number]/. For example, if the full URL to a dashboard is https://mysquaredup.com/SquaredUpv5/page/dashboard-enterprise-applications, you need to use /page/dashboard-enterprise-applications.
Open a web link
