CVE-2022-46785 - Prototype pollution leading to XSS
CVE: CVE-2022-46785
Prototype pollution leading to XSS was found in SquaredUp for SCOM 5.5.1.8414.
What should you do?
If you are using a SquaredUp DS version earlier than 5.7.1.9085, update to version 5.7.1.9085 or later.
SCOM Edition | Versions earlier than 5.7.1.9085 | 5.7.1.9085 and later versions |
Azure Edition | Versions earlier than 5.7.1.9085 | 5.7.1.9085 and later versions |
Community Edition | Versions earlier than 5.7.1.9085 | 5.7.1.9085 and later versions |
Acknowledgement
22.02.2023 | Initial release |
