CVE-2021-40091 - SSRF issue
CVE:CVE-2021-40091
An SSRF issue was discovered in SquaredUp for SCOM 5.2.1.6654.
What should you do?
If you are using a SquaredUp DS version earlier than 5.3.1, update to version 5.3.1 or later.
Acknowledgement
