Blank browser after installing SquaredUp DS v5
The browser may show a blank page if you are accessing SquaredUp DS on an unsupported web browser.
This may be seen for the first time following the installation or upgrade, when you will need to open SquaredUp DS in a web browser to run through the setup wizard.
Check that the browser is supported for use with SquaredUp DS. On the server you should also check the server's default browser (search Windows > default apps).
Supported Browsers
SquaredUp DS works best with the latest versions of Edge, Chrome, Firefox and Safari on desktop & mobile.
On SquaredUp DS v5 Internet Explorer is not supported. Older browsers may show a blank page.
On SquaredUp DS v4 Internet Explorer 9 and earlier versions are not supported.
For more information see System Requirements, Server Spec and Sizing
